Binding Install
Re: Binding Install
Yes - the ivoriod-in-acetone trick works great. You can make joints totally disappear buy melting them together with acetone applied to the surfaces and by filling any gaps with the ivoroid paste.
scamp
Re: Binding Install
Finished binding the top and scraping everything down. Very happy with results. No gaps etc. Also discovered that a rolled over single edge razor makes an excellent scraper. Body more or less done. On to the neck and frets.
Re: Binding Install
Very nice, clean job
