Fretboard extension shim or taper?
Re: Fretboard extension shim or taper?
Nice job. It looks like you meant to do that! (i.e. it doesn't look like an afterthought or a fix-up.)
Looks like a good recovery!
Post by Stray Feathers »
Well I was lucky because I had made the fingerboards probably too thick in the first place! Sometimes things work out in the end.
