A more-or-less copy of a Martin OM
Dot inlays complete
I've completed the installation of the fingerboard abalone dot inlays. I'm in awe of Dave Nichols (Custom Pearl Inlay) and others who do such beautiful inlay work. For me, dots were hard enough! If you look closely, you may see that some of them aren't aligned in the fret spaces just right. Fortunately, they aren't so far off as to be blatantly noticeable.
I cut the holes with a miniature carbide end mill of the correct diameter, which gave an almost-flat-bottomed hole, and glued them in with a drop of superglue.
The inspiration for the dot layout came from the fingerboard of a Harmony Soverign.
You can also see one of the fingerboard alignment pins, used to position the fingerboard on the neck.
The top, in progress
This isn't a particularly inspiring picture, but it's the top, with the halves glued together, in the process of being reduced to final thickness. I've planed it down to just over 0.2", but I think I will give up on the planing and rely on Carter's thickness sander from this point on. Although I can use a hand plane fairly well, the thought of reducing a couple square feet of spruce to a uniform thickness of 0.1" or thereabouts is a bit terrifying, especially when I think of how much the wood cost.
It's beginning to respond well to taps. When another 0.1" is taken off it ought to be a very "live" top.
I may have mentioned before that it's red spruce from an old-growth tree harvested from Baxter State Park in Maine. I don't want to mess it up!
The bridge
Going back through the postings, I see that I haven't posted a picture of the bridge yet.
I'll also include a shot of the form tool I ground for making the heads of the bridge pins.
Re: A more-or-less copy of a Martin OM
Nice job on this MainGeezer. (didn't catch your real name, sorry)
What kind of wood is the bridge made from?
Nice looking bridge and shop made pins.
The bridge is also dogwood. It darkens up considerably when a finish is applied. (Compare to the unfinished fingerboard photos.)
Why dogwood? I had a piece and wanted to do something with it. I discovered that it's a very hard wood, considerably harder than hard maple, but it machines quite well. What a dogwood bridge may do to the sound, I have no idea.
While I'm at it, here's a shot of the top in progress. Rough-cut to shape, sanded to thickness, and two of the rosette rings cut.
I'm planning to bind the edge of the sound hole, probably with a ring of black walnut to match the back and sides and neck.
Geezer,
Great blog. Interesting alternatives to the norm. Keep up the good work.
-tommy
-tommy
Rosette complete; sound hole cut and bound
Even though I carefully test-fitted the strips for the rosette, the lengths were incorrect when I actually went to glue them in place. For a few minutes I was afraid the whole thing would be a disaster, but real-time "adjustments" were mostly successful and the final fit isn't too bad. The black walnut binding on the sound hole opening fit quite well. The big problem was the abalone ZipFlex strip and the purfling strips on either side of it. But the end result is acceptable, I guess. It probably looks worse to me than it will to anybody else.
If you ignore the fact that there is no back or sides or bra
If you ignore the fact that there is no back or sides or bracing and the neck isn't shaped yet and other minor details, it's starting to look like a guitar.
(n.b none of this is glued together yet!)
The back with center joint reinforcing strip
This is of passing interest only because I used trimmings left from cutting out the top to get the cross-grain reinforcing strip for the back. You can just see the pencil marks where the braces are going to go. I'll have to cut out the reinforcing strip where the braces go.
