Absolutely. Most cabinetmakers and caseworkers call the type of dovetail we use for guitar necks a compound dovetail or a sliding dovetail. The type used on drawers and boxes would be the standard or simple dovetail. That always made me chuckle....ain't nothing simple about chopping 16 pairs of those suckers per box and having it all go together without twisting up.tippie53 wrote: The dovetail in a guitar neck is different than the drawer dovetail .
Dovetail v. Bolt (my long experience)
B. Howard
Re: Dovetail v. Bolt (my long experience)
rienk
What is the difference between a "simple" dovetail, and the ones they use for other series?tippie53 wrote: Martin is now using a simple dovetail to replace the mortise and tenon on the 16 and lower series. I can't say that it is an improvement .
I assumed that all DT joints on a guitar were compound...
neck joints used by martin
The dovetail on the Martin neck uses a 20 degree dovetail with a 9 degree taper on the tenon.
The bolt on or mortise and tenon is the same across the board 3/4 in wide and 1 bolt it is a glued joint
the simple dovetail is what is also known as a sliding dovetail.
rienk
I'm not sure I'm visualizing it properly... how does a sliding dovetail get pinched?tippie53 wrote:neck joints used by martin
B. Howard
It tapers both directions so as it drops in it gets tighter.
The simple or sliding dovetail won't get pinched it is just an angled tenon . That will not get tighter as it goes into the joint the standard will.
http://www.youtube.com/watch?v=L3YJh9OT4mw
here you can see the joint and the double taper. I don't have any pictures of the new sliding dovetail but it is a simple joint.
