Turrets Syndrome? Finishing with Tru-Oil
Re: Turrets Syndrome? Finishing with Tru-Oil
Tim, I think that is a fine method. I like the micro mesh.
glenklein
You'll have to excuse my ignorance again, but I've never used micro-mesh...
Is it something you can find at Lowes or Home Depot? Or do you buy it online? Does the brand name matter, or is micro-mesh the brand name?
What do you use as a lubricant/polish when buffing out?
Follow my first build...
http://glenklein.blogspot.com/
It is a brand - don't remember where I got my kit but you'll find it online or maybe a local woodcraft if you've got it.
I use all of these grades: http://www.rockler.com/product.cfm?page=6461... I think you'll find them cheaper though.
I use warm water with a drop of detergent as lubricant.
Please be sure to let it FULLY cure before attempting any polishing.
glenklein
Got it! Thanks again!
Right now Woodcraft has the little pad kit of micromesh on sale; you get about 6 or eight grits for a little less than $12. A good way to try it out, and probably enough to do one guitar.
glenklein
Thanks Kevin... I'll go check it out.
I use the Micro Mesh soft touch pads (2x2), not the sand paper. They aren't really sanding pads they are polishing pads and I believe were made originally for polishing airplane windshields back to clear. I can polish several guitars before they wear out. I use water and a drop (only a drop) of soap detergent to lub as I polish. It's great for a quick polish on a customers guitar that is brought in for repair ( I start about half way up the grits), it's my little extra and you'd be amazed at how they react when they get it back a whole lot shinier than when they left it.
