1st build; time to stop dillydallying!
BEJ
Re: 1st build; time to stop dillydallying!
Have started on my first cut back. Tried to bend the sides using hot pipe, didn't work out so well. So I made a new bending set up and this worked out a lot better with a few issues.
Looks like this one will be a learner, got some misalignment of the head and tail blocks. Should be able to work around it, and do better the next time. Need to square up the top, might have install a patch to line up the neck. Need to be creative here as most patching looks like crap or trying to cover a big screw up.
A few pics of bending rig and what I've done so far....
BEJ
Got a little work done on this one. Built a T bar sanding rig for sanding out rim edge, one of those things I wished I'd made sooner after seeing how well it worked. a few pics...Used a binding rig set up to hold guitar and pivot for T bar, nice to use something I already had.
I did my edge sanding with a similar set up on a few guitars before I made my Sanding dishes.
It always seemed to work very well, and simple too.
Looks great
Looks great
BEJ
Got a little done the past few days, call this "A mess of parts" a few pics...
Oh, does that ever sound familiar! With my builds, the first one was built according to the directions of the luthier teaching me, so that one is fairly normal. From that point on, however, things tended to veer, sometimes quite a lot.BEJ wrote: ↑Fri Jan 20, 2012 10:50 pm
I'm the type of person that couldn't follow a plan step by step if his life depended on it, sort of a knucklehead so I just hope I don't veer off into left field with this. With all the build threads I've looked at the past few months it's easy to get attracted to different ways to do something....
I don't necessarily see that as a bad thing. You're doing this (presumably) for YOUR enjoyment, so do what you want, although some experience with proven designs before straying too far afield is probably advisable. My biggest veerage was probably my experiments with falcate (curved) bracing for the top.
BEJ
Got a little more done, now a box. The hard stuff begins now, never has an easy time with binding and sure this one will be a PITA. a few pics...
Now would be a dandy time to tend to the neck location and angle, before binding.
BEJ
You might be right, still thinking on what to do with it. Did a rough set up....
BEJ
Got around to doing a little work on this one. Hate binding but it had to be done. Have treated this build as a learner model, thus have used some left over or 2nd/3rd grade materials. And it looks it in some places. A few pics...
BEJ
Got some more work done on the cut off, done with rough out on the neck. It still needs some adjustment, had some trouble getting the fret board edge to line up flush with body. If I ever do another cut off will know what not to do if I can remember it. a few pics....
