Another supplier for you: https://www.mcmaster.com/
Not necessarily the cheapest, but their range of products is mind-boggling.
Router Bit Size
Re: Router Bit Size
scamp
Re: Router Bit Size
Well I got my 1/16 inch router bit in the mail today and used it to cut out and install an experimental rosette with my home made black turquoise black purfling, It worked remarkably well. Some pictures below. Thanks for all the suggestions.
Here is the rosette with the purfling ( after bending it on my bending iron and install )
Re: Router Bit Size
Nicely done! Bruce W.
