Before gluing braces . . .
Bob Gleason
Re: Before gluing braces . . .
Waterbase glues, like Titebond, do not have gap filling properties. They are not like epoxy or Gorilla Glue. The tighter fitting the joint is, the better waterbase glues work. I think that is, technically speaking, the reason that smooth planed joint surfaces are better than rougher sanded ones. However, that may not matter with a large gluing surface like a brace. It may matter more with much smaller surface joints like top and back center seams. I am not by any means skilled enough to confidentally plane a spruce top to thickness, but making braces and joining tops and backs with a plane is relatively easy and far more satisfying to me than using sanding or power jointers. However, as I said before, modern glues will compensate for limited craftsmanship and the end product will probably be fine whether you plane or sand. Planing is better, but it may not actually matter in the end.-Bob
when in doubt learn to test your process.
I , like Bob agree the mating surface of the joint is 100% critcal. If you force a joint , it is doomed to fail.
I have tested my joinery techniques and here is what I learned. Toothing doesn't really to that much of anything.
even dust doesn't seem as much to make a joint fail . what I did find is
clamping time and techniques
Torrified wood takes a longer clamp time I do 24 hr min.
How old is the glue and how is it stored
so use fresh glue.
When in doubt test a joint.
tite bond will tell you that you can unclamp in 45 min. I have pulled them apart on purpose to see and was surprised how how well the bond was.
HHG Fish white glues have different clamp times.
No need to over tighted a clamp. But this is one this I did find , glue will act like a lubricant and allow things to move , water based glues need to dry to glue tight , these are hide glue and fish.
White ( elmers ) and yellow ( tite bond and elmers carpenter glue ) are PVA and these all cure. There is a chemical reaction that completes the bonding process.
this all sounds like over thinking but in the end , a good cover of glue , is when you see glue and the wood under the glue. You want to see a little squeeze out not a flood.
when you break the bond you want to see wood fibers come up and stay in the glue joint. That is a successful joint. So learn surface mating and clamping procedures.
Water wipe up doesn't effect the glue. I use a sharp stick to get the worse up. I wait about 5 min to let the glue boogafy and then use a soft tooth brush and brush in the same direction.
so use fresh glue.
rcnewcomb
Another vocabulary word!boogafy
- Randall Newcomb
yup Definition : when glues sets up much like a good booger
Origin Latin root Boo Scary secondary root iffy not so scary
bftobin
A fresh surface always gives the best results when gluing. If the braces have been sitting around for days, I'll give a quick swipe with a scraper. Sometimes I use 1000 grit sandpaper, but a scraper is ideal. Alan Carruth has all the tech data.
Gary Davis
^ I'm thinking now I'll have to wait until I get back from vacation for gluing. I'll be scrapping the bottom of the braces then and maybe a bit of the soundboard as well.
Thanks y'all.
Thanks y'all.
I call it boogering up, but boogafy is better.
