Building a Fox bending machine
Bob Gleason
Re: Building a Fox bending machine
I'm sure John sells the right springs for most guitar work, and buying from him is the easy way to get the right ones. I bend everything from Soprano ukes to jumbo guitars in the same bender, so I have a lot of different size springs. Ace Hardware here has a complete stock, and so does Home Depot. Springs should be fairly easy to find locally in any urban area.-Bob
http://www/mcmaster.com has just about any spring you can imagine.
