Number 15 for Sammy is finished!
Re: Number 15 for Sammy is finished!
Thank you all. Ed, it bent with no issue at all. This is the second set I've used from the billet I resawed. I get much better and faster bends now that I have the silicone blanket, verses the heat by light bulbs. Yeah, clean bends, no cracking. What I love about the blanket.....the bend is done in about 6 minutes!!
How do I attach mp3 sound files?
I have a couple of this guitar to share if possible.
Pick up is LR Baggs I-Beam through a small Acoustics 100 amp.
I think it sounds pretty good. :)
Congratulations on a great looking guitar!
Now, what can you tell me about that case?
Having recently completed a Redwood and Maple guitar, I am very appreciative of your material choices. It is lovely, and the ebony looks great
The maple bent beautifully. Fox style bender with silicone blanket. Spritz sides, bent around 280 degrees. No issues
The case is the Gator Flight PRO TSA case. This guitar is going to India, so much needed protection.
What do you guys use to post sound files these days?
I tried to attach mp3 and it won't take. Why not allow these files to be posted?
Okay lets try this.
It is not great playing but the best I can do for now. :)
https://youtu.be/MdGFWUezU-g
Beauty!!
I like the sound. The different notes are clear and separated. It doesn't sound "muddy" at all.
