Three 0's
jread
Re: Three 0's
1st scratch built box closed. Wash coat only. All mahogany w/ Englemann bracing. The x braces are slightly shorter (.45") than my target (.5") so let's hope it doesn't fall apart.
I'd like to find a different saw for the kerf cuts. Fret saw has a depth stop but the cuts are a bit thin.
Undecided on tinting or staining under a shellac french polish.
Neck's are coming along slow but sure.
Re: Three 0's
Martin's top bracing of the 00 in the mid 30's was .45 and less, so you should be OK
jread
Re: Three 0's
Thanks! I appreciate that. Box seems sturdy enough and has a nice tone when tapped around the lower bout and bridge plate. I got this wood on sale and am glad I did another practice run before doing the more expensive sets cuz I love this guitar!ruby@magpage.com wrote:Martin's top bracing of the 00 in the mid 30's was .45 and less, so you should be OK
jread
Re: Three 0's
rough dovetails came out. Next challenges are fretboards and bending a cutaway on the next one up.
jread
Re: Three 0's
As a new builder, I get overloaded w/ information sometimes. I've see guitars w/ this strip of wood in the tail block (cross grain from the block) and think I remember a post about it here but can't find it. So I've made one and thought I'd post inquiring on just why I am doing this. :D
This is a mahogany strip from a back so is about 1/8" deep. I've read this can help the block from cracking. As this one will have a pickup jack here, I thought I'd try it. Any opinions or more information on adding a strip into the tail block?
jread
Re: Three 0's
after more searching, I found the answer. It is for crack mitigation on drop and should be plywood.
source: blues creek quick tip.
https://www.youtube.com/watch?v=1PWWJLOGk6A
jread
Re: Three 0's
i miscalculated this distance and was off by .1" which doubles as it's 1/2 the width of the fretboard. Instead of selling me an expensive blanket, John recommended the clothes iron to remove this block and the fish glue released easily. I cleaned it up and it was long so trimmed the side and reglued. Back in business.
my fretboard will be 2 1/8" at fret 12 so this 14th fret distance is 2.175" /2 = 1.0875. Got it on 2nd try.
The form and insert are working ok.
jread
Re: Three 0's
2nd home-made box, 1st cut-away. There are a couple of issues along the edge that I hope the herringbone and side binding will cover but we'll see. Looks like any issues if visible will be minor so I'm pretty happy.
jread
Re: Three 0's
Particularly happy w/ this one.
I re-sawed a 5/4 board on my tablesaw to make these back and sides. I broke 3 sets of sides bending this cut-away so glad I was making them from cheap but very nice looking (to me) lumber. This grain has just the look I was going for.
This mahogany was much more difficult to bend than the less figured set i posted earlier in this thread. This one sure taught me how to plane and chisel with the grain.
John's new bending video helped quite a bit. I agree w/ his recommendation that the mahog likes about 275f/135c on the bending iron and just hit w/ a sprayer before bending or else trouble comes in many ways.
Re: Three 0's
You're doing a great job! They're looking really nice.
