you should be ok
remember that often it is as much technique as what you use
Wet Sanding Procedure
Re: Wet Sanding Procedure
I use the micromesh then Novus #2 as a final polish. You can stop at anytime you're satisfied with how your guitar looks.
I get the micromesh pads and Novus #2 from Amazon. The entire set of micromesh pads, goes from 1500 to 12,000.
