new finish test
Gibsonman
Re: new finish test
Post by Gibsonman »
tippie53 wrote:been hanging for a few days will check to level sand this weekend the neck is in process will post pics soon
John what is the process to sanding it out? Wet sanding?
Also after that are you then done with spraying it anymore?
Re: new finish test
level sanding is done wet 800 1200 1500 2000
then lay on a few more coats wet level 1200 1500 2000 and then buff and polished
Rag Thumb
Re: new finish test
Post by Rag Thumb »
Are you liking this process and result better than your previous experience with Minwax Wipe-on Poly?
Rex
Re: new finish test
yes this is more glossy for sure.
I am doing the water lacquer on the next test body
so in a month or so we will have another one ready
Re: new finish test
I level sanded on Monday and had to do a final top coat the finish is as good as I ever saw with rattle cans. I leveled with 800 1200 1500
then applied 3 coats Monday night 1 hr apart
I also started the headstock and neck
acousticguy
Re: new finish test
Post by acousticguy »
Great idea to review this product John, thanks for all the work you do. This product does go on clear correct?
Re: new finish test
You should warn people to put their sunglasses on before springing those pictures on them! Those guitars are gorgeous.
