Starting up my build again
Re: Starting up my build again
Diane
Do you use both kinds of tape? Masking and bias? What keeps the bias tape from getting glued to the body where it contacts the corner?
Michael Haines
Post by Michael Haines »
The bindings were the plastic ones that came with the kit. Not sure I like the idea of gluing plastic to wood anyway. Thanks Mike Haines
Mike
Not that it means anything for your personal guitar, but the vast majority of guitars built today and for the last 75+ years have had plastic binding, As soon as celluloid came out in the 20's it became a favorite. Even the highest quality names like D'Angelico used it. There are several glues that do a fine job of it.
Michael Haines
I used the Duco glue that most use and the bindings peeled off with little effort. I will try wood on this one. I will cut them slightly larger than what I currently have so I can clean up the channels a bit.
ruby@magpage.com wrote:Diane
Ed, I tape the guitar with 3M green tape or masking tape, as I bind, then I wrap it with the cotton twill tape.
I clean up any squeeze out immediately, so I don't generally have problems with any tape sticking. The binding is almost completely covered by the binding tape. I double check for squeeze out, but very little of the binding is exposed when I wrap the guitar, especially in the problem areas. So, the twill doesn't come into contact with glue.
I'll be taking photos of the quilted mahogany build that will show the whole process.
Michael Haines wrote:I used the Duco glue that most use and the bindings peeled off with little effort. I will try wood on this one. I will cut them slightly larger than what I currently have so I can clean up the channels a bit.
Sounds like a good plan. I'm partial to wood bindings too.
