Fretboard binding -mitering corners?
ChuckBarnett
Re: Fretboard binding -mitering corners?
Here are some photos of what I was working on. I ended up making a Paul Sellers style miter 'box' (Youtube) and, best I could, cut the 44+ degree slot into that. When I dry fit the corners I found that my angle wasn't precise, so I simply drug the angled surface along a finer sandpaper in the hopes that I was making things better.
I did the best my eyes could do and glued it up. Found that one corner was open on the inside so I did the Dan Erlewine (Youtube) superglue and fine shavings trick. And it worked!!
You do realize that you're the only one who will ever notice any flaws, don't you?
ChuckBarnett
Likely that is true. But I'd like to minimize that as best I can. :)
Of course. I think we all try to achieve perfection. I do find, however, that on occasions when I'm driving myself to a complete melt-down over some detail I've screwed up, it helps to back off a bit and reflect that nobody else is going to obsess over it anywhere near as much as I am.
In case anyone is interested, here is a 6 1/2" long aluminum miter box.
Zona 37-240 Aluminum Thin Slot Miter Bo ... fBbZ6TYG5Q
ChuckBarnett
I've had a couple of those;-)ruby@magpage.com wrote:It's not a mistake unless you can't fix it
ChuckBarnett
Thanks again, Diane.Diane Kauffmds wrote:In case anyone is interested, here is a 6 1/2" long aluminum miter box.
And I ordered that little pull saw you mentioned. ;-)
