Zebrawood 00 Venetian Cutaway
John J
Re: Zebrawood 00 Venetian Cutaway
Carving begins.
Learning every day.
John J
Moving a little slow on this one. Too hot/humid to get much done. I've finally finished installing and leveling the bindings and top purfling. I had pre bent the bindings and hand bent the purfling except the cutaway purfling section. Saved that for last. Installed at the same time with titebond. The last section was bent with the aid of super soft and water and a combo of my bending pipe and a heat gun. I'd get it quite warm and then push it in the rebate on the guitar body and hold while it cooled. Quite a few repeats of this step and it finally got close enough to glue in. Sanded level and I'll only have some very minor gaps to fill.
Learning every day.
Sure is looking nice there John.
Very very nice. The use of the same pattern in the purfling and rosette works very well
John J
Thanks guys. Finally getting this one done. Started finishing (z-poxy pore fill and Tru oil). Bridge is rosewood, zebrawood and bubinga. I've found this little saw blade for xacto handles works really well for slotting the bridge pin holes.
Learning every day.
How did you work out the overlap of the bass side and the treble side? It looks as though you first glued the bass side to the head block so the end was flush, then glued on the treble side so the treble overlaps the end of the bass side. Is that the way you did it?
nice one
John J
Took me a minute to realize you weren't talking about the bridge pic. Yes that's exactly the way I did the neck block/side attatchment. Seemed the most logical way.MaineGeezer wrote:How did you work out the overlap of the bass side and the treble side? It looks as though you first glued the bass side to the head block so the end was flush, then glued on the treble side so the treble overlaps the end of the bass side. Is that the way you did it?
Learning every day.
