Build #2: StewMac Mahogany Dreadnought
rcnewcomb
Re: Build #2: StewMac Mahogany Dreadnought
Post by rcnewcomb »
Adding the smaller braces to the redwood top
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
I spayed lacquer on my radius dishes AND I used the 3M 77 spray adhesive as suggested by Ed. This worked much better. I'm still frustrated by how much sanding I have to do. I'd swear that when Kathy Matsushita sands her kerfing it takes about 5 minutes tops and it is perfect. I sanded on this for an hour to finally get it right.
- Randall Newcomb
You have realize that Kathy is a super woman.
rcnewcomb
Post by rcnewcomb »
I bought some light blonde shellac from LMI: ->Link
Kathy gave me instructions for mixing:
Here’s a chart: https://www.shellac.net/PoundCutChart.html
What I do is, into 1 cup alcohol, put 1 ounce flakes for a 1-pound cut, and 2 ounces flakes for a 2-pound cut.
I bought one of those digital kitchen scales — I put a bowl on it, set it to zero (tare), and put flakes into the bowl till I have the ounces I need.
I then crush them up in one of those little coffee bean grinders, so they’re more like a powder, almost — they’ll dissolve faster that way.
Put the shellac into the jar you have the cup of alcohol in, cap it, and every so often, swirl it around. I forget how long it took to fully dissolve.
After it’s all dissolved, use a coffee filter to strain it into your little bottles.
I mixed 1/2 cup of 1lb, and a full cup of 2lb.
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
I sanded the top kerfing. I'm having better luck getting the sandpaper to stick to the radius dishes now:
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
Dry-fitting the back to the sides
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
Carving top braces and cutting the notches in the sides for the X braces
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
I put some 1lb shellac on the top to help protect it (plus I wanted to see what it looked like). Neither the top nor back have been glued on yet.
- Randall Newcomb
John J
Post by John J »
That top is gonna look beautiful.
Learning every day.
Danl8
Post by Danl8 »
Good blog! Thanks for posting Kathy's shellac recipe. I woulda never thought of using the coffee grinder...brilliant. I'm learning almost more than I can handle at this forum. :-) Can't wait to 'hear' your finished dreadnought.
