French Polish Question
Re: French Polish Question
Lots of them will work if properly applied. I personally like clear pore fillers and generally use Z-POXY FINISHING RESIN P40 an epoxy based pore filler. It has a slight amber tone. I also use a West Systems epoxy (105 Epoxy Resin - 207 Special Clear Hardener). It does not have the Amber tone. You can find application videos on youtube Todd Stock has a good set of videos. I have also used Aqua Coat Clear Wood Grain. It is easier to apply and a good choice.
You can use opaque fillers like Pore-0-Pac but use a very dark one, I would use black, or the Rosewood will look muddy.
I used this stuff http://www.lmii.com/products/finishing/ ... ear-filler with reasonably good results.
I used the Aqua Coat as well and was very happy with it.
Oldsoldier
I have my channels cut and ready to install the bindings and purfling. I plan to use the Aqua Coat Clear grain filler. Should I apply the filler before or after the bindings and purfling are installed?
Oldsoldier
After. It'll interfere with some forms of glue. It'll fill any voids in the purfling, etc. Plus, depending on your choice of binding, it'll fill the binding as well. If you used ivoroid, just wipe it off while it's wet, or just gently sand it. Besides, even the ivoroid will be covered by your selected form of finish.Oldsoldier wrote:I have my channels cut and ready to install the bindings and purfling. I plan to use the Aqua Coat Clear grain filler. Should I apply the filler before or after the bindings and purfling are installed?
Oldsoldier
Thanks again. I was thinking along those lines but wanted some assurance that it was the right thing to do.
