12 string bridge crack
Re: 12 string bridge crack
I like to do this with a cracked bridge
A tape under the bridge plate
B gently sand the bridge so that some dust gets into the crack
C take some birthday candles and set into the pin holes
D wick in some CA
E sand and 0000 steel wool with kiwi shoe wax
I will light the candels and allow the wax to thicken them so I can a nicer fit. You can also use sawdust. The tape will help keep the super glue from dripping. You need to get the CA all the way onto the crack so apply a drop at a time and go between the holes and do that about 2 3 times. Once you see the CA at the top of the bridge you know you should be good
Zen
Post by Zen »
[q
Thanks for that John--would you let me know if you can open this link --its the only way I have found so far to post a pic/
https://picasaweb.google.com/1021752021 ... oevZ7K71aw
RUSTY
that one is severe indeed. This may be more a candidate for replacement Check to see that the bridge plate is not also broken.
glasalle1
Post by glasalle1 »
looks like it split along the grain - maybe on the next one drill the pin holes in a slight semi circle?
Glenn
