Gluing on the fingerboard....
Re: Gluing on the fingerboard....
I use one but not like the martin I make mine from the neck block to the transverse brace , trapazoidal shape about 1/4 in outside the fretboard to about 1/2 . That supports the area a good bit and it is in an area that has slight tonal intact but great for structure
Metalone72
John,
Does the piece you add have the grain going in the same direction as the top? How thick? And is it tight up against the neck block and UTB?
I can't recall but I was told to use epoxy which I did on my first. The permanence factor scared me but the intonation is close enough, though not perfect. If everybody else here is using Titebond then I will do so with the necks for nos. 2 and 3.
I ended up using Titebond for the fingerboard, and it seems to be fine. As somebody said, that's a huge gluing surface so as long as you apply and use whatever glue you're using correctly, it's probably going to be okay.
Personally, I would avoid epoxy because it is so non-reversible, but it does work!
I use Titebond as well and have had good results. I also use a small amount of Duco cement under the truss rod, just enough to make sure that it stays put and doesn't rattle (I stay very clear of the end, so that it doesn't hamper adjustments).
I also sand a shallow hollow under the fretboard. The "hollow" starts where the truss rod opening starts at the top, and stops at the neck block. It extends out from the truss rod opening to within
~1/4-5/16" of each edge of the board. This way, if there are any sanding boogers that I don't notice, or the neck is't perfectly flat, the board fits snugly against the board, with no edge openings.
I started doing this after my first two fretboards showed tiny gaps in a couple of places. The hollow worked for me, and eliminated the problem.
