My Ooops project, Working on a special strap.
Re: My Ooops project
Hey Ed, I like the idea of using a screw also but like you I also don't use the strap button thingy so I'm reluctant to use the screw.
Ed and David you will probably want to install an end wedge anyway to clean up the bottom seam of your guitars. That could cover the hole. Having the screw through the time that you profile the rims and install the linings would make a big difference in the ease of keeping things square.
Everything went great with the routing! I have some friends coming over so it will be tomorrow before I get any pictures up.
David and Ed, if you don't use a strap button on the rear you can just add a tail wedge and not drill a hole through it. My problem now is that my hole is about 1/4 inch off from where I would like the strap button to be so I am contemplating filling the hole before I glue on the tail piece...
Looking real good. I like the "Martin Kit" label, I never saw that before.
My wife and I made the Martin label. In Bill Cory's book he had an example of a label he made.
The routing went fine, I would have never got it right without the router stand I made. I used 2 bar clamps from harbor freight to make the jig.
More pictures
More pictures
I glued the tailpiece on tonight. Tomorrow I plan to install the bindings.
More pictures.
More pictures.
Can you show a couple of more shots of the binding jig you made? Not clear from the pohotos. thanks.
Your guitar is look great! You're really coming along.
I made a label for my OM too. It serves as a record of the build: OM (body, bracing type) CSPW (Carpathian Spruce, Peruvian Walnut), 482014 (48th week of 2014), 001 (first gutiar).
Since the theme is roses, I found a small vintage brass seal with a rose on it, and sapphire blue colored wax a couple of weeks ago. I'm affixing a seal to the corner of the label the next time I change the strings. LOL
![Image](http://i141.photobucket.com/albums/r59/kauffmds/Guitar%20Building%20Chronical/DSCF0155.jpg)
Great looking label Diane! I didn't think about putting a serial number on it until after I glued the label in.
Here are some more pictures of the router stand. If I build another guitar, I would make the jig with wheels maybe from a drawer slide. That way it would not "bind" at all.
I finished the tail wedge last night so this morning I started gluing on the bindings and purflings.
