Your way of removing dried glue?
Re: Your way of removing dried glue?
This is a luthier site so call it a sound hole putter inner LOL
6'x2" pvc + cap + BBQ ignitor + hairspray + potato = lots of fun. take it to a cornfield or lake to really see how far they go...
It's been a while for me but that's the jist of it.
Let us know if the glue came off with John's potion.
Good news - it worked perfectly!
Bad news - it's time-consuming. Took almost 5 minutes!! :-)
Thanks John.
DaveB
Ohhh I forgot about the wet the towel set on guitar , make coffee, have a donut , drink 2nd cup not check on the glue
I always forget that part
LOL
DaveB
Now I see - so I lay the guitar on a linty towel soaked with 1 cup of wine vinegar and a teaspoon of water. Let it set, then sand with 40 grit wet and dry. Or 60 grit if you're a purffechionist like me.
DaveB
Post by kencierp »
I have not used it but have been told it works great
http://www.goofoffstainremover.com/
I believe there once was a thread about Goof Off in this forum
I have used Goof Off to remove pick guards. Work a little under an edge on a rag, peel up as you work a little more, and it will dissolve the glue, not hurt the lacquer finish.
to pull pick guards I use a hair dryer . A small amount of heat will get that to release . Another great glue remover is ky jelly mixed with white vinegar . this works for tite bond , white and hot hide glue. .. Epoxy and CA need trained termites
rgogo65
Post by rgogo65 »
Here's something that works...Ken H. may even take care of your squirrel problem if you plan it right...
then..maybe not...the Wife and all ya know...mine lost her sense of humor lately...
you'd think after 45 years...
Yeah, well...then on second thought, like I said...maybe not... :)
http://www.coolestone.com/media/895/Anvils_Away/
