A new basic tool
Re: A new basic tool
Post by naccoachbob »
For both pieces, totalling 60" by 20.5" or so. $40.
And he cut them. And no charge for that!
I asked at a local (Lufkin, Tx.) Lufkin Tile Co., if they had scraps for sale.
I could not believe that price either. The place happens to be next to one of the offices I cover in the next town over from me, and I've parked right in front of that piece many times. Finally decided to go in.
I'm going back next week to do some work. With the ideas coming in on this thread, I might get a number of dedicated smaller pieces.
Maybe a 6" x 18" for fretboard work.
Something for my wife and daughter to use for baking, food prep, etc.
Post that video if you will. I think John did one on one of his Youtube videos.
But I'd like to see another. I can never get too much video.
I'll buy a smaller one for the cat's head stone. Or chunk it at the cat.
Either way, money well spent.
Alternatively, here is another option. This e-bay seller sells quartz sanding blocks. The standard ones are guaranteed flat within 0.0015". The premium reserve stock is guaranted flat withing 0.0002". He claims they are the perfect weight for leveling frets and he offers them long enough to contact all frets on the fretboard at once. I'm sure these are more flat than probably any sandpaper you can buy so I'll bet it would work nice. I'm planning on getting one. Here is a link to the premium reserve block that is more flat. Note that he offers different lengths so make sure you have the length you want before ordering. It includes some sandpaper for fret leveling.
http://cgi.ebay.com/Quartz-20-SANDING-B ... 5671550064
I'm going to take that idea and get back to that shop.
A 3" piece about 18" to 24" would be a good leveler, use it for installing frets, shooting board.
I think I read somewhere that you can use acetone to clean up the adhesive used to stick sand paper to that stuff.
Sometimes you can pick up a piece of a 4" or 6" wide backsplash that is left over after cutting a piece to length at a reasonable price. I picked up a 6"x28"x1.25" back splash for free at a local place that cuts and grinds granite.
Darryl Young wrote:Alternatively, here is another option. This e-bay seller sells quartz sanding blocks. The standard ones are guaranteed flat within 0.0015". The premium reserve stock is guaranted flat withing 0.0002". He claims they are the perfect weight for leveling frets and he offers them long enough to contact all frets on the fretboard at once. I'm sure these are more flat than probably any sandpaper you can buy so I'll bet it would work nice. I'm planning on getting one. Here is a link to the premium reserve block that is more flat. Note that he offers different lengths so make sure you have the length you want before ordering. It includes some sandpaper for fret leveling.
I have one of those, nice for what it does. Only 2" wide though. I want a piece like the one in the back ground.
Tim
I'd be a bit afraid of using a very straight sanding block for frets on a steel string. My guitars have a 16" radius, and I could possibly wear down the middle section using something as heavy as the granite.
My experience is very limited, so maybe someone with more could chime in.
naccoachbob wrote:I'd be a bit afraid of using a very straight sanding block for frets on a steel string. My guitars have a 16" radius, and I could possibly wear down the middle section using something as heavy as the granite.
I use it to check for level. Here's tutorial link:
http://www.tdpri.com/forum/telecaster-d ... 101-a.html
I think you would work it side to side instead of end to end so the radius is maintained. At least that is my guess.....I've not done it.
I like the straight edges for dressing frets. I work each string line then blend in with a radius block
