Easy way to locate center of soundhole?
sylvan
Re: Easy way to locate center of soundhole?
I always tell my students that when you want to build a guitar always build the fretboard first. Everything thing on the instrument comes from the measurements obtained from the fretboard. If you build in that manner there will be no horrendous mistakes!
Sylvan Wells
Wells Guitars
Bay State Guitars
http://www.wellsguitars.com
Wells Guitars
Bay State Guitars
JRHall
Very good point. The fretboard/scale length is the only critical dimension on the whole guitar. If you have a little experience, you can build a perfectly good instrument, after that point, just by eyeballing it.sylvan wrote:I always tell my students that when you want to build a guitar always build the fretboard first. Everything thing on the instrument comes from the measurements obtained from the fretboard. If you build in that manner there will be no horrendous mistakes!
Maybe it's obvious to all, but when you join the 2 pieces of the top, glue them up where one side is maybe 1/4 or 1/2 inch offset from the other side. That way you'll be able to easily find the centerline. Sometimes the glue line in Spruce is really hard to find.
when you glue the plates you just sand one plate on the joint edge corner so the center line is easy to see.
