tone of back
Re: tone of back
rstbkt wrote:So do I need to remove the back braces and start over? Hope not because I used tite bond on those instead of white glue.
I think you are fine.
The back braces hold the radius side to side. The radius sanded into the rim (or sides) is what forms the radius in the back from end to end. So you only need the radius dish to sand the radius into the rim if your braces are already radiused.
The important thing on gluing the cross grain braces on the back is the humidity reading when this operation is done as that becomes the "normal" level where the radius is correct. At all other humidity levels the radius will either increase/decrease so the dome will rise/fall.
rstbkt
Re: tone of back
Post by rstbkt »
We are running between 35 and 40 % RH right now. I figure I'll try to glue them when we hold around 40 for a day or two. Best I can hope for.
Tom West
Re: tone of back
Post by Tom West »
rstbkt: Listen to what Darryl is telling you.
Tom
rstbkt
Re: tone of back
Post by rstbkt »
Oh Sorry. I meant I would glue the front on when the RH stabalizes for a couple of days. I'll go back aand see what the RH was on the day I glued the back braces on and try to match that when I glue the front ones on.
