Truss rod
Zen
Re: Truss rod
Just found a set of feeler guages and heres the story
Capo on first fret and fingered the 13th. I can just slip in the 0.25 at the 6th fret.
Without the capo theres 4/32 at the 6th fret and 5 /32 at the 12th fret
RUSTY
Re: Truss rod
I assuming you mean .025. I think the neck is bent too much. I would set the relief as described below. Back off on the truss rod. To fix the intonation I would look at where your strings are breaking on the nut and saddle. Intonation is affected by the length of the strings relative to the position of the frets.Zen wrote:Just found a set of feeler guages and heres the story
Zen
Re: Truss rod
johnnparchem wrote:I assuming you mean .025. I think the neck is bent too much. I would set the relief as described below. Back off on the truss rod. To fix the intonation I would look at where your strings are breaking on the nut and saddle. Intonation is affected by the length of the strings relative to the position of the frets.Zen wrote:Just found a set of feeler guages and heres the story
No --its 0.25 with the feeler gauge ?
RUSTY
Re: Truss rod
simple question
is this a 2 way rod and are you sure you turned it the right way?
Zen
Re: Truss rod
If you mean is it a 2 way rod similar to whats included in the stew mac kits then no its not one of those. I am also building a kit from stew mac and its a red two -way rod thats enclosed ,whereas the one in this guitar is a straight rod enclosed in a metal casing and yes its fitted correctly as far as i knowtippie53 wrote:simple question
RUSTY
Zen
Re: Truss rod
Zen wrote:If you mean is it a 2 way rod similar to whats included in the stew mac kits then no its not one of those. I am also building a kit from stew mac and its a red two -way rod thats enclosed ,whereas the one in this guitar is a straight rod enclosed in a metal casing and yes its fitted correctly as far as i knowtippie53 wrote:simple question
Should have explained it is enclosed in an aluminum U-channel as well
RUSTY
Re: Truss rod
.25 is 1/4", 8/32. That sound way high.Zen wrote:johnnparchem wrote:I assuming you mean .025. I think the neck is bent too much. I would set the relief as described below. Back off on the truss rod. To fix the intonation I would look at where your strings are breaking on the nut and saddle. Intonation is affected by the length of the strings relative to the position of the frets.Zen wrote:Just found a set of feeler guages and heres the story
Re: Truss rod
.25 = 8/32 is 2x higher than the 4/32 you got with the capo on.Zen wrote:johnnparchem wrote:I assuming you mean .025. I think the neck is bent too much. I would set the relief as described below. Back off on the truss rod. To fix the intonation I would look at where your strings are breaking on the nut and saddle. Intonation is affected by the length of the strings relative to the position of the frets.Zen wrote:Just found a set of feeler guages and heres the story
B. Howard
Re: Truss rod
OK, based on this description it is not .25" (1/4") and I doubt it is .025" as that is just under 1/32" and would most likely be measurable with a machinists ruler. My set of feelers has a .0025" gauge and that seems to make sense based on the above description and the initial statement of having "tightened the truss rod all the way". So I would suggest backing off the truss rod while carefully measuring until you obtain the proper relief, then we can tackle the rest of the set up and work on the action. Proper action will go a long way towards helping intonation.Zen wrote:
I put a capo on the 1st and finger the 13th -low E- as Brian said and theres very little play at the 6th -in fact I couldnt measure it but the string moves slightly when I tap it
Rusty
B. Howard
Re: Truss rod
Have pondered this a bit more here, and just to confirm my previous thoughts the feeler gauge you are using when you get the .25 measurement is real thin and flimsy? or is it thicker like the tip of a small screwdriver?
