David is off line now
Get Togethers, Workshops, Open Houses (Any Place, Any Size)
DavidRNichols
Re: David is on line now
Post by DavidRNichols »
mjmeehan wrote:I don't have skype so I'll just ask here.
I've used abalam many times but have only used actual abalone pearl once and was afraid of sanding through the color. Is there a way to tell how deep the color runs? or should I inlay the pearl as deep as possible to eliminate this? Sometimes pearl pieces can be pretty thick. Thanks.
Color on the ablam will be consistent for about 2/3rds of the way thru the shell. With solid shell, you can look at the back and see how consistent the color is from the top. Sanding usually changes it a little, but normally not enough to disrupt a pattern.
DavidRNichols
JVan wrote:I do not have Skype either, Just wanted to say Hello to Mr. David, Love your work you are a true artist!
THANK YOU!
DavidRNichols
DavidRNichols wrote:David's here ...
www.custompearlinlay.com
mjmeehan
Post by mjmeehan »
Thanks for the info.!
My next question would be How to route for extremely tight corners and still get a flush bottom with no gaps? Like an oval with pointed ends?
I did this once but using my dremel I only got close and carved out the rest by hand. Luckily, it was on an ebony fretboard and I used dyed glue to hide the gap.
I personally wish to thanks David for his time in doing this . I cannot thank him enough.
To let you know David also does give classes in inlay and sell supplies for this art. Don't be afraid to contact him later for your needs . There is a link on the side in the sponsor section for David and Custom Pearl Inlay
He will be helpful. Over 50 years of doing this , I wish I knew what he forgot.
DavidRNichols
mjmeehan wrote:Thanks for the info.!
If you use one of the inlay routers from Blues Creek or Custom Pearl Inlay, they will take bits down to .020 which will leave you with a corner that is invisible when filled.
DavidRNichols
David Nichols - Custom Pearl Inlay
call (518) 483-7685 est Sunday w/questions
mjmeehan
Post by mjmeehan »
Thanks, Dave. I appreciate your time here and the help.
One last question.. What are your thoughts on Abalam vs. straight shell? Are there instances where one has an advantage over the other?
Thanks again!!
DavidRNichols
mjmeehan wrote:Thanks, Dave. I appreciate your time here and the help.
Thanks again!!
My preference is to use ablam wherever there will be a finish over it. The solid shell does not have the glue lines, which sometimes are visible when unfinished (like on a fingerboard). The advantage of ablam is the size of the pieces and the consistency of color.
