Making bridge blanks
Re: Making bridge blanks
you are most welcome
glad it helped
glad it helped
seanbig
This tutorial on How to Make Bridge Blanks can now be found at www.BluesCreekGuitars.com. If the tutorial was helpful you can Facebook Like it or Google +1 it at the end of the tutorial.
Other Blues Creek Guitars' Step by Step Tutorials can be found at Blues Creek Guitars Tutorials.
Sean Big
Sean@BiggerRoom.net
Sean@BiggerRoom.net
Nice tute John, thanks.
Would you mind showing us how you cut your saddle slots and mark and drill the pin holes?
Here I use a milling machine with a digital readout. I have to put together a slotting jig for a drill press. The old Martin through bridges we done with a saw. Marking any hole for the pins is easy.
Start at the center , In most cases the holes are about 3/4 inch from the front of the bridge . The go from there. A trick is to use chalk , then pencil marks are more visible. Lets say an example is 2 1/4 spacing. The holes will be .450 apart. From center to 1 and 6 1 1/8. Use a sharp nail to make a center start and you will reduce the drill bit walking.
Think this is a good one to dust off and repost.
stay tuned for how to slot and drill
ColestineGuitar
Yes, good material. I'm thinking of many uses for a
grizzley oscilating sander.
there are many jigs I have made to go with the sander , In fact that may be a great topic for a new video
thanks for the idea
thanks for the idea
songman101
I like the pictures and the process John thanks songman101 this will really help me to be much more efficient and save time & $ great job also.
Definitely my favorite John Hall How-To. When you get the slotting and drilling part done it'll be even more favorite....
-tommy
-tommy
