finalizing top bracing
turnertj
Re: finalizing top bracing
Post by turnertj »
Cool!
Tj Turner
Author, Scientist, bumbling Luthier
Author of Lincoln's Bodyguard
www.tjturnerauthor.com
turnertj
Post by turnertj »
Hey all...
I have a brace material choice to make, so I thought I would have you weigh in so I can understand the trade-offs better. I made an x-brace yesterday from some Adirondack Spruce. It seems good, but the grain is pretty wide. I also have some sitka with much tighter grain. They appear to be the same stiffness (measured through my scientific bendy test...the use of the word 'bendy' should illustrate how scientific this test is!). Which one would be better for brace material?
Tj
Tj Turner
Just my opinion but the one with the least runout and straightest grain would be my choice. Be sure to check runout by splitting both directions as grain running out the bottom or side will weaken the brace........but grain running out the bottom/top is the worst case as it weakens it more in the plane where it needs to provide the most strength.
I will be finishing up bracing today and will post the photos later today. There are many ways to make bracing . When I opened my wood I didn't have anything to split as it was ready to go . If you do split , the first split should be across the grain . This will decrease the amount of Runout . Then split with the grain square up and size.
With all that done I rip the brace stock from the largest down to the smallest. I preped 77 sets of top braces in this exercise. All red spruce. I have some 1/4 in and most 5/16. Once sized it then gets rough shaped and radiused. Then the notch is cut.
All my braces are .625 high for the Main X and truss rod. I pretty much use a similar brace like Martin. I will alter some for Gibsons. Dust masks for all . keep and eye out
turnertj
Post by turnertj »
Hey guys...
I thought I heard mention somewhere of someone not tucking in their x-braces. When I think about the forces the top is under, it seems that tucking the x-brace into the kerfing in the lower bout might not be necessary, or add that much. I can see it being more useful for the upper bout and the brace north of the soundhole.
Comments?
Tj Turner
Yes, tuck the UTB and X-Brace in the upper bout. Your choice on tucking in the lower bout.
Jim_H
Post by Jim_H »
I tuck both ends of the X's and the UTB.
I wonder what an eperienced repair person would say about the long term plusses and minuses of tucking other braces (i.e. tone bars).
Rick Davis is the one whose example I followed, and between he and Cat Fox, there have been a lot of repairs through his shop. I suspect if there was any significant value to tucking the tone bars, he would be doing it.
I've always inletted the X braces and the UTB brace. I can not see any benefit to not doing it, and at least I feel some security that it is helping in the structural integrity of the guitar body to top juncture.
I prefer to tuck the X-braces at the lower bout if for no other reason than it helps me to locate the top to the rim, less chance of a mis-match when I close the box.
Martin tucks the truss rod and X only on the top the backs , all are tucked. I do it the same way. The braces not tucked I will fade the ends to the top
