2nd kit
SKBarbour
Re: 2nd kit
managed to get the cross brace off wihout a problem. no other braces were affected so hopefully when I receive the new brace I can fit it back in and glue it up with no problems. until then I'll work on the back being more careful not to have gaps. The best thing about mistakes is that your less likely to do it again. Yup, less likely cause nothing is definate.
kyle
SKBarbour
Re: 2nd kit
all right so I figured out what the problem was. I had a nice tight glue joint at the cross. apparently too tight , while it fit great without the glue when you add the glue the joint gets a little tighter. I know this now because it almost happened agin this time . fortunately I caught it quick enough that i was able to remove the brace , clean the glue off and recheck the joint. after opening things up a little bit it glued together great. I'm glad I figured out the problem cause now I know for sure what to look for from now on.
kyle
SKBarbour
Re: 2nd kit
I have made some progress and it's going well since my cross brace mishap.Thanks again to Ken at KMG for the great customer service and providing me with a replacement brace so quickly. At this point the side top and back are assembled waiting to have the top binding channels routed. I decided to do some abalone purfling on the top but didn't have the router bearing I needed to get the depth required. Stew mac only sells bearings to cut up to s .210" ledge and I needed .220" . It took some searching but I found the right bearing. Hopefully I can get this done this weekend. here are some pictures of some of my progress.
kyle
SKBarbour
Re: 2nd kit
heres a few more pics. I decided to use binding with laminated purfling but was a little ......alright I'll say it ,scared to bend the waist on figured maple bindings. So I made up a bending form with some scrap from the garage and this, well I'm not sure what to call it but it worked!
kyle
Re: 2nd kit
Good to see you making progress!
SKBarbour
Re: 2nd kit
a few more pics of my progress
kyle
Re: 2nd kit
That looks really good! Clean, attractive, just right. I'm enjoying watching the progress.
Re: 2nd kit
very nice. You should be very proud .
Re: 2nd kit
good looking work. I really like how the purflings worked out on the sides.
