Two good pictures.
Re: Two good pictures.
Looks great Tony! I gotta get black cloth! might even make me look better!
Tony,
I'm glad you remembered to put the strings on the outside of this one, but your label inside is crooked.
Truely it looks great. I like the closeup of that nut too. For some reason I can't seem to get my nuts in shape like that.
SKBarbour
Well Kevin, I have a great deal of experience handling my nuts, so I am able to manipulate them to almost any shape I choose. you should work on your nuts slowly and deliberately. It really helps when you do not get to aggressive with your nuts. I find that the more time I take carefully coaxing my nuts into the correct shape and level of shine, the happier I am with my nuts. I am sure you will agree.
I also find it helpful to look at a picture of a nut you want to copy during the shaping process. When I did it from memory, my nuts were poorly shaped.
SKBarbour
man i saw that coming. the guitar looks great Tony, but I will not comment on your nuts.
kyle
kyle
kyle
Yup Tony, I agree tonally!
OK...so to be serious about the shape of the nut on my guitar, this is how I do it:
Once the nut is cut to the proper width, I put it in place and knock off the edges so that it tapers to conform to the neck/ headstock transition. Basically, I get it to fit, and look good, as an almost rectangular block.
Next, and I do this one half of the nut at a time because I do not have an expensive StewMac nut and saddle vise, I clamp it into a vice, using some scrap to keep it from getting marred.
I let one half stick out of the vise, pretty much so that, when I am sitting, it is pointing at my face and I am looking at the profile, bass to treble. I get that half shaped how I like it, then flip the nut, shape the other half, remove from vice and fix any lumpy spots. Then I polish it, and install.
Not so hard if you look at it from the side. Also, if you do not do it while it is glued in place!!
Seriously, I was setting you up with the nut thing....I figured you would run with it.......
Now, I do like how you shaped the back side of the nut. I slope mine, but they don't have that nice rounded contour, so in that respect I was being serious. Good job there. I might try and get mine shaped more like that next time.
I should have my latest done (again) this Saturday and will take some pictures, or, have my wife who takes better pictures than I do take some pictures, and then you can see my nut. :>)
Kevin,
Am I that predictable? I suppose so. I cant wait to see the pictures your wife takes of your nut.
My nuts are a private affair, as they do much to contribute to the quality of the overall package. If I must say, though, Tony, I do admire yours. Is it wrong?
