Finished my brother's parlor guitar!
Re: Starting a new steel sting o size guitar for my brother.
Thanks, I have the peterson tuning software application on my laptop. The software includes a tap tuning function stretching the tap out to a measurable length of time. I will make sure the plates are not in tune. I may leave the back braces a little taller.
Remember the top drops a semi-tone (so 'they' say) with the addition of the mass from the bridge. Of course I'm just repeating what I've read... do with it what you will.
Post by Tony_in_NYC »
Ahhh...so perhaps tuning the plates to the same note, and then adding the bridge would be the perfect solution!!
Or not. I dont think my skills are to the point that I need to worry about tuning the plates the same. It wouldnt even happen by accident to me. What I do is, I try to do something, and then fail. So if I tried to tune them the same, I would fail, and there would be no issue!!
I got a bit of work done today on the guitar. I used my Christmas joiner plane to true up the face of neck and move the nut position up the neck to where I want it. The 15 degree angle is breaking right at the nut poistion.
I setup my router table with a ½ inch straight router bit to route for the truss rod and 2 carbon fiber rods. I would have epoxied the rods in but I bought ½ inch rods instead of 3/8th. One more LMI box coming my way.
I then joined the plates again using my Christmas joiner. I got close with the plane but I need to do a few strokes on 120 grit sand paper that I have on a tempered plate of glass. I was too lazy to make a shooting board so I sort of turned my bench into one. Ultimately I think I will run a board along the bench to help me hold the joiner true.
In any case I had no problem gluing the plates together with my quick jig. I profiled both the top and the back and thicknessed the back on my new drum sander. The spanish cedar back felt more like a top when I got close to thickness. I will up the height of the braces a bit.
It is coming along nicely. Keep those pictures coming!
I agree with what Rick states. I try to get the 2 plates at least a 1/2 tone separate
John,
That looks to be a great combination of B & S and top wood colors.
Are you doing a dark binding treatment, like EIR or EBony?
Kevin Sjostrand wrote:John,
Thank Kevin, I have decided on Ebony, it is funny you asked as I went back and forth between EIR and Ebony. Also mainly because I want to try it I am going to try the narrow zipflex purflings. I am stuck on a rosette design. I am leaning toward a wood ring with zipflex on the inside and outside. The zipflex has a very narrow black edge which may look good without additional purfling strips for the rosette.
