Starting a J200 Jumbo guitar
Re: Starting a J200 Jumbo guitar
I already had the end and neck blocks made. I got the sides cut, the blocks glued in, and both the top and back radiused on the radius dish to the correct body depth.
Boy this will be a fat guitar!!
Today I got the back kerfing, handmade kerfing, glued in place.
While that was drying I started the neck from a 36" Honduran Mahogany blank. Scarf joint and stacked heel glued up.
Glued up the back plates with a center strip of EIR with BW purfling on both sides. Cut out the shape and final thicknessed to .110"
Then I glued up the first binding/purfling. EIR with BW side purfling.
Update:
I have all 4 bindings/purflings made up and I have the side support braces installed.
I started on the fretboard today. I'm using a nice piece of EIR
which will be bound with strips cut from the same blank.
Holding off right now on gluing on the back braces for a few days for the humidity to drop some.
Okay so the plans I'm using call for a 25.5" scale length fretboard. I started to lay this out using both inches and millimeters, thinking I would draw the lines then attempt to cut the slots in my slotting jig box without a template. 🤯
I quickly realized this might be a fools errand, getting it sufficiently accurate. Then I thought; why not just do a 25.4" scale length? I have the LMI template that I use for all my dreds and OMs. There is only .100" difference! How much could that make in the execution of the guitar???: tone, volume. playability. etc?
So I decided to use the 25.4 scale. I cut the slots yesterday using my LMI template and all went great .
I looked at the plans and to me this amount at the saddle location can't make much difference, and it it will, I can just shift my X brace .100" closer to the soundhole??
And actually, the plans call for a 3/16" nut, but I like using a 1/4" nut which will actually make that scale difference less than .040" less as far as the saddle goes, and I can probably just follow the bracing placement per the plans.
So what do you all think? Will my guitar not sound like a real Jumbo if I do this?
Post by Stray Feathers »
Kevin, in my limited experience (ten guitars, not one of them a jumbo) I would do exactly as you are doing. I think it is one of those very minor changes that some will debate endlessly, and others will insist you would never be able to reliably hear a difference. And I don't think your guitar will implode. Bruce W.
carld05
Post by carld05 »
It's fine Kevin. I used a Martin neck on one of my Jumbos that had a 25.4" scale and it worked fine. Didn't even make any bracing changes. Bridge slot placement is the critical issue as you know.
Thanks Fellas for the words of encouragement
carld05
Post by carld05 »
I checked the "J200 Style" plan from LMII that I use and its scale is 25.312", a typical Gibson scale. Pretty close to 25.4".
This guitar has sat for awhile but got back on it this week a bit. I installed an Indian rosewood end wedge with BW purflings which will match the body bindings.
I glued on and carved the back braces and will fit it to the rims tomorrow. Pics then!
