How does one improve on the durability of a shellac french polish finish?
Srick
Re: How does one improve on the durability of a shellac french polish finish?
Way back in college chemistry I was taught you could not easily create 200 proof alcohol because of water in the atmosphere. And regardless, grain alcohol works just fine. A little goes a long way. I prefer the grain because it’s pure ethanol - no methanol, which is toxic, and no denaturants of unknown stripe. Of course grain alcohol is toxic too, but your body can metabolize it to an extent <lol!>.
I get my flakes from shellac.net and it’s pretty easy to whip up a batch. This is what I use for finishing. For a quick blast of shellac, sometimes I will spray some Zinnser Bullseye into a cup and use that. It’s always fresh, but it does have a shelf life.
Just today, I may have shortened the French polishing protocol by days. I porefilled mahogany with GluBoost and then, after scraping, I sanded the surface with Assilex and bufflex sheets. At that point, just a few coats of shellac have provided a wonderful gloss, plus it’s already flattened and mirror like. Almost too good to be true. I’ll keep the forum posted on this.
And back to your original question, there are resins that can be added to the shellac to increase its hardness, but there’s not a lot of detailed information out there. Simply letting the shellac age on a surface increases its hardness and durability over time.
beginner
thank you....i just went too fast, beginners mistake....at some point it looked so pretty and i had hoped that more was better
looking forward to seeing how your technique worked out
I always thought (and still think) I was blessed by magic when I watched that lumber turn into music. Every time.
jread
I agree. There's something really cool about those moments when your project goes from carpentry to musical instruments. My biggest charge will always be seeing and hearing talented players make music with these things I built.
I knew it was not easy, although I had assumed it was because some amount of water (5%) got carried over in the distillation process. I didn't realize humidity played a significant role.
It is possible to buy 100% alcohol, but I expect one would have to keep it tightly capped and use it quickly before it absorbed moisture from the air.
Srick
You’d probably have to add an anhydrous scavenger to the liquid to remove any water. Way too complicated! 190 proof Grain alcohol works just fine.MaineGeezer wrote: ↑Tue Jul 08, 2025 12:14 pmI knew it was not easy, although I had assumed it was because some amount of water (5%) got carried over in the distillation process. I didn't realize humidity played a significant role.
I just remembered that Sandarac is the additive used to make traditional shellac harder. It’s a whole ’nother rabbit hole to follow down, just like so much of luthiery.
Years ago shellac and wax was a common finish for hardwood floors. While certainly inferior to mode modern finishes, it must have had sufficient durability to be chosen for that application. Seems as though a guitar should be less demanding than a floor.
Tomcat
Unless you're playing bluegrass...MaineGeezer wrote: ↑Wed Jul 09, 2025 6:17 am Seems as though a guitar should be less demanding than a floor.
beginner
the shellac french polish finish in my opinion sure looks gorgeous. That said if and when i ever finish this one....I think my next build will use either one of the UV cured options or a light coat of hardwax oil. it would be interesting to see if i can identify a notable difference in acoustic quality.
Srick
Follow-up: this process certainly has helped. Doing a quick search, I find several references to using the Eagle Abrasives system as opposed to traditional wet sanding. The Assilex material is expensive, but lasts and lasts. I am finding it really effective at flattening the finish every X coats.Srick wrote: ↑Mon Jul 07, 2025 5:05 pm Just today, I may have shortened the French polishing protocol by days. I porefilled mahogany with GluBoost and then, after scraping, I sanded the surface with Assilex and bufflex sheets. At that point, just a few coats of shellac have provided a wonderful gloss, plus it’s already flattened and mirror like. Almost too good to be true. I’ll keep the forum posted on this.
And the GuBoost, being a modified CA, is much harder than your traditional oil or water based filler. IMO, you ‘ll get a better starting surface.
I still have problems dealing with a soft spruce top which as you might expect, is unfilled. It requires a lot of time and shellac. I can very easily see why nitrocellulose lacquer became so popular. But due to its toxicity and flammability, I’m not going there. There are several prominent luthiers using water based polyurethane acrylics, but it’s a whole ‘nother system to purchase and learn about its subtleties. It’s just one more variable that I don’t want to add in the mix right now - shellac is the devil that I know.
The biggest issue I have been having, however, is my patience. You need to not only keep working on a French Polish finish, you need to also leave it alone so that the alcohol can gas off and the finish can harden up. And it looks like every solvent based finishing system (ie. Not catalyzed and UV systems) needs to be left alone to fully harden before final polishing.
