Your way of removing dried glue?
Is there a good safe product for removing dried glue from a finished surface?
DaveB
Re: Your way of removing dried glue?
Dave,
If you are talking about a guitar finish, I would think scraping it off with a razor blade down to the finish is going to work pretty good, then you can just re-polish the spot.
what kind of finish ? what kind of glue ? most glues will come off with water .
Polyurethane, original Titebond.
Water, then?
DaveB
Kevin - thanks for the input, and if I had a steadier hand, scraping would be the way.
this is a piece of cake .. Take a cup of water and 1 table spoon of white vinegar , Take a small piece of paper towel towel and wet it let it set for a few minutes , that will soften the glue .
Out Standing.
DaveB
Once you've fired taters out of a homemade cannon, you've set the upper limit on fun...
DaveB
Post by naccoachbob »
deadedith wrote:Once you've fired taters out of a homemade cannon, you've set the upper limit on fun...
DaveB
Please elaborate! I'm still a kid. Sorta.
Oh, Man, I got vampire squirrels that aren't taking the hint with an airsoft gun on full automatic.....You gotta show me how to build one of those!
I've got plans from a website. I'll see if I can fuind it.
DaveB
