Nothing new - reminders of things that have saved me lots of hours of re-dos; having to do with stray sawdust. One little bit at the wrong time can cause you grief.
Sandpaper left out should at least be face down.
If you use a vacuum and brush attachment to pick up sanding dust, be sure to vacuum the brush as well between grits at least.
If you use a rag to wipe off dust, clean it after every wipe, an easy way is to vacuum it.
i use a shop vac on the other side of the wall to cut down noise, and a cheap HF foot pedal.
Pictures are not even necessary, but I had the camera so.....
Reminders
Reminders
Re: Reminders
The best reminder of all, "If momma ain't happy, ain't nobody happy"
Re: Reminders
No argument there...
