I must be crazy
Re: I must be crazy
Well i bungled my purfling job on the back. First time marking, cutting, by hand in maple. Not too easy.
For now moving forward. I added a black line to standard BWB purflng which helped fill in my overly wide uneven width channel. Many gaps to fill. Ugh!
I bought the right tools for the next time on the top and that should come out better.
I may even start over with a new back with some lessons learned.
TEETERFAN
Re: I must be crazy
Stradivari had trouble with his first few back purflings.
Seriously, you are learning a new techniques and that moves you forward. It takes a lot of nerve to get out of the ole comfort zone. I bet the purflings will be hidden somewhat by the varnish. Anyway, it’s looking like a violin! Thanks for the update.
Kevin Doty
Kansas City
Kansas City
Re: I must be crazy
Making progress. The outside arching of the back is close to complete. The purfling after scraping it down is not as bad as i thought it would be. Not great but im going to go with it. Ill do better on the top.
Started carving out the inside of the back. Wall thickness is 5mm at the center to both ends of the C bouts the tapers down to 3mm at the purfling ledge. A series of holes are drilled in the plate to set an initial depth for carving......and carving......and carving.
Did i say there is lots of carving?
Re: I must be crazy
Inside of back is done
Now starting on the top
Re: I must be crazy
That's a work of art - are you sure you want to close it up?
Re: I must be crazy
Ha ha. It's got to make music one day
A little progress. Started carving the top
Re: I must be crazy
It's really coming along Kevin. I don't know if I could take this on.
Re: I must be crazy
Thanks Diane. For sure a different animal.
Installed the purfling and leveled it. Next step is to carve a recurve where the purfling is. The arching still has alot left to go too. For now this project is in the box. Getting back to my OM project.
Re: I must be crazy
I have the top almost done.
Finished shaping the outside and carved the inside today. Thickness is supposed to be 3mm so I drilled into the area to be carved 3.5mm as a gage and carved with gouge and mini planes.
Next step is to cut the F holes. I have them traced on the top ready!
Re: I must be crazy
More pics
