Bridge location
Post a photo of something you are working on today. No need to explain or write anything. A photo is worth a thousand words. If you must write something caption your photo with the "File Comment" field when uploading an attachment. Keep it short and show us some photos!
Forum rules
Pictures please.
Bridge location
The rules so no need to explain
jread
Re: Bridge location
Post by jread »
This bridge is super nice. What a treat to see and an inspiration for my next build.
Re: Bridge location
looks great Ed.
Kbore
Re: Bridge location
Post by Kbore »
Rats.
Measure Twice,
Karl B
Re: Bridge location
Okay, now I see the holes.
Did you originally locate the bridge in the wrong position? I did that once. I made an oversize repair bridge to cover my goof. As pretty as that bridge is, i would suggest that a belly bridge would cover the mistake after filling the holes.
Re: Bridge location
When I positioned the bridge the saddle against my jig, I had it flipped backwards. I used a light above shining through the holes to a mirror inside to check that my bridge plate was in the right place and found one of the holes was OFF the bridge plate. Sinking feeling, but here it is with the patches and a first round of Endurovar after leveling.
PS - LOVE the Endurovar so far
Re: Bridge location
Wow! Excellent match of the color and grain. I suspect that at the moment the patches are all you can see when you look at the top, but a month from now you'll never notice them.
I cut a big divot out of the back of the headstock of my first guitar. The patch doesn't match anywhere near as well as yours do, but as this point I never notice it .
Re: Bridge location
Good job Ed!
