Mezerna Compound
Mezerna Compound
Which Mezerna compound(s) do you use to obtain a high shine?
Re: Mezerna Compound
I use these three
med finish ( 16 and 18 ) and 175
banjopicks
Post by banjopicks »
3? How do you clean the wheels in between or do you not bother?
You really ought to have a separate wheel for each grade.
banjopicks
Yeah I guess you could change one of the wheels.
Thanks for the info.
I don't to much till final buff
so I will bounce the grits from 16 to 18
I have 2 wheels a small 12 in and a 18 in wheel
the smaller one is domet and the larger one flannel
I get them from casewell grizzly used to carry them here are some that will work
wheel
https://www.grizzly.com/products/woodst ... -rpm/d2518
https://reverb.com/item/31076874-stewma ... gJNMvD_BwE
