Finish Max HomeRight Sprayer
Selah
Post by Selah »
Has anyone used a Finish Max HomeRight sprayer to apply nitro finish? I have this sprayer and have used it on my wood working projects spraying water based Poly Acrylic finish with great success.
Re: Finish Max HomeRight Sprayer
never have but no reason not to try it. Spray some cardboard and see how it lays out
Selah
Post by Selah »
I used the sprayer to place shellac (premixed) and nitrocellulose lacquer. It did a great job. I don’t know how it compares to the air sprayers as I do not have one, but I think it did a very respectable job. I’ve included a few photos of the final product.
Selah
Post by Selah »
I have to post an update. After sanding the finish, I realized it just did an pretty good job with the spray, but my next project I will use a “real” sprayer hooked to an air compressor. It will give me the finer control of the spray that I need for a great finish.
you may have missed some things
did you not thin and use retarder?
did you seal and fill
if you don't do good prep you won't get a good end result. Looks like you would do well
finish is about technique so
seal
fill
seal
use thinner and retarder
I do a 60 40 mix of the first 2 coats than do 65 35
my tinner is 1/3 retarder 2/3 thinner.
you can mix 70 30 .
I spray about 6 coats hr apart let set after a few days level sand. I may do 3 finish coats 50 50 then level sand buff and polish
it takes time to do a good lacquer finish
please let us know your details in the finish process and we can see if you need some advice
Selah
Post by Selah »
I followed Stewmac’s finishing book. I sprayed shellac, filled, and then sprayed three coats of lacquer about an hour apart on day one, three, and five. I level sanded on days two and four. After a week, I wet sanded for smoothness using 800, 100, 1200, 2000, 2500. I then buffed. The end result was pretty good, but I have a couple places where I sanded a little too thin and got to bare wood I fixed them, but didn’t get the same color. I think one place where water got in. They are all small, so I probably will just ignore it.
what brand lacquer ?
I prefer the sanding sealer of vinyl sealer . They build better.
what filler ?
I think your sprayer will do fine
you may need to do a thinner retarder in your mix.
what size needle do you have in the sprayer?
Selah
Post by Selah »
I used the guitar lacquer and filler from StewMac. I used a bullseye shellac that was premixed from Lowe’s. I tested the premixed shellac before using to make sure it was “fresh” and it did well. My order was shellac, filler, lacquer ... nine coats of lacquer.
The gun has no needle choices. The air output from the gun is always the same. It only has the ability to vary the amount of lacquer. I had it turned down so it sprayer very little at a time so I was putting in thin coats. It did alright at the beginning, but it got worse as time went on. I decided to use a “normal” air sprayer the next time.
Selah
Post by Selah »
I just completed refinishing my guitar with the Stewmac spray gun. The finish is a lot smoother and I’m a lot more impressed with the finish. Comparing the Stewmac spray gun to the HomeRight Sprayer ... the Stewmac sprayer does a MUCH BETTER job!
krrtlr1
Post by krrtlr1 »
Good info. Anything special for your compressor or lines for keeping air dry?
