Buffing idea....
kelley71
Buffing idea....
Post by kelley71 »
Hi guys,
I am new in the way of buffing. I am curious about this link below...
http://www.autogeek.net/lake-country-ccs-pack.html
It is a 6 pack of various 4 inch pads of your choosing that will attach to a drill. I have seen the Porter Cable polishers and HF Polishers. But I think for this small of a surface These might work well with the correct compounds. I don't trust myself nor want the expense of a large wheel buffer at this point.
What do you guys think? My Rigid Cordless drill has a no load high speed of 1650 RPM, so I could run at half and not burn.
Thanks....
Re: Buffing idea....
I use an arbor , before that I used a random orbital buffer. Any drill will leave swirl marks. It is all about the compounds and cutting rates. You can get a car random buffer to use on the final buff with a wool bonnet and Maquires swirl remover #9
kelley71
Post by kelley71 »
Thanks Mr. John
The last thing any of us wants to do is spend hard earned money on things that might not work.
Best regards,
Kelly
Go to Harbor Freight and buy the 5" RO sander for about $20 with the 20% off coupon, then get a couple of Surbuf pads, about $13 each at Woodcraft or Rockler, one of those places. Use a rubbing compound one and a final polish, swirl remover type for the second. I used 3M rubbing compound and Novus #2 polish and achieved a very good high gloss swirl free finish on 5 guitars before I set up an arbor buffing system. Shoot it worked so well not sure I really need the buffer now.
Try the Surbuf's and an RO sander, I think you'll like the results.
penndan
Post by penndan »
+1 for the Surbuf pads on a random orbital sander.
Good enough for the kind of women I go out with.
I tried those Autogeek pads. Did not work well for me. They are still sitting in a box.
