Buffing Compounds
Buffing Compounds
For those of you out there that use buffers, what manufacturer and grade compounds are you using to complete your work? I recently purchased Menzerna Medium and fine and was wondering if I should be using x-fine?
Re: Buffing Compounds
I have those same two compounds and they work good. I haven't used the X-fine.
What kind of finish are you polishing?
I really like the mezerrna I use 16 and 18 you can get it from Jescar
@ Darryl - Target Coatings WB Acrylic Lacquer EM6000 Gloss
@ John - those are the two I got. They just got here in the mail (got them from Stewmac $26 ea, is Jescar cheaper?
yup
Doh! I used them today and what a huge difference for the better. I really thought it may be my technique but I think that was OK. from now on it's Menzerna for me all the way!tippie53 wrote:yup
watergunn
What is the website for Jescar?
All i can find is their fret wire sites.
Jescar call them the phone # is on the site
I use Menzerna Medium, Fine, Swirl remover.
Designate a different wheel for each one. Never contaminate a finer wheel with a courser grit, as 1 medium grit on your swirl removed will leave scratches you'd probably rather not have.
I've been toying around with buffing wheels for a corded handheld drill from harborfreight. Cheap enough to get a handfull of the buffing bonnets to keep them clean, and uncontaminated.
