Satin finish
watergunn
Satin finish
How do you keep a satin finish to appear satin instead of glossy? After level sanding and spraying the final top coats do you wet sand or do you use steel wool? Or neither?
Re: Satin finish
you use a satin or matte finish and no sanding , You can cut his back with steel wool or sandpaper
watergunn
Re: Satin finish
So after you spray several coats you use steel wool to level. Then shoot a couple more coats and just let it cure out?
Re: Satin finish
If you are using satin you don't do anything. there is an additive to this that makes it satin. All I do is add 10% thinner when it shines up from use I may cut it back with 0000 steel wool
watergunn
Re: Satin finish
Great, thanks.
watergunn
Re: Satin finish
How many coats of satin do you usually spray on a neck?
