Target coatings brush finish schedule
tricktrack
Post by tricktrack »
Can some give me some advice for a schedule for the target coatings wb em2000 brush on finish. Do I need to use a pore filler paste then their pore filling brush on? Do I just use their pore fill brush on then the top coats? Do I need to use their shellac?????
Completely confused.
Thanks for any info
Re: Target coatings brush finish schedule
Best to follow their suggested schedule. They have a forum on their website where you can find info on compatibility issues and other issues by using the search. There is a ton of info on their products there. It's where I started when learning to spray EM600.
tricktrack
Does anyone see an issue with compatibility with timbermate pore filler target ultra seal amber weaker and the 2000 brush finish?
B. Howard
Post by B. Howard »
I always test product compatibility by making sample boards. Run out the process you want to test on a scrap of wood, hopefully a cutoff from the project. I make detailed notes of each step on the back for future reference. I will sometimes run out 2 or 3 of them and test for abrasion resistance etc before committing to a project done that way.
