Re-use tuner bushings?
I've used Grover tuners on about eight ukuleles, drilling the post holes, and reaming them out with the appropriate Stew Mac bushing reamer. On the last two, when I pressed in the Grover bushings with my drill press, there was a lot of lacquer chipping and cracking. So two questions: 1) To avoid this in the futre, should I use the reamer after the finish is on, or before, and just do a thorough manual reaming of the finish before pressing the bushings? And 2) If I remove the tuners and bushings to make repairs, can I press the original bushings back in when it's fixed? Thanks--Bruce W.
Re: Re-use tuner bushings?
I pre drill before finish and use a chamfer bit after finish to break the corner of finish to avoid chipping
The only reason I can think of not to re-use the bushings is if they are worn so much the shafts are no longer supported properly.
TEETERFAN
I have a lot of experience with Fender bushings on electrics. I have cracked necks forcing in bushings that are too tight, so opening up the hole a little is best. I kinda shoot for a fit that needs a light tap or two to seat. On worn holes I drizzle cyanoacrylate glue on the bushing and let that dry completely, building the thickness until it is snug again.
To avoid chipping on finished necks I drill the holes in stages and drill the first 1/16”-1/8” with my drill reversed (standard bit).
Kevin Doty
Kansas City
Kansas City
