drastic restoration
drastic restoration
got a new one in this week an employee guitar from Martin. I will post pics soon. to describe this would be difficult. This is one whaky repairs on the head stock
I hope to show how bad a thing can be yet still be repaired
Re: drastic restoration
This is the beginning
The tuners were changed at some point and the holes elongated to fit the different spacing. I really like the wood screw addition to hole the post in place. On top of that , the very top there is a metal rod installed . This is horrible amateur work at its finest.
The guitar needs a neck reset , and new pickguard. A few loose braces and some minor work. The plan will be remove the crap out of the headstock and repair that. I will post pics as I proceed.
Hope you guys enjoy this one.
Good Lord. Don't you just love amateur repairs? I'll be really interested in how you deal with this.
This will be fun to watch!
Do the tuner repairs make them work OK?
the tuners are cheap and terrible I will replace them
Hope to have some more pics Monday
today I got the neck off and started the headstock repair. I will have to order a plug cutter. The tuners are in the trash and I have a new set ordered. The spacing was all wrong for a slot head. The headstock shows signs of a crack.
My plan at this point is to get the holes plugged then I will machine the headstock and cap the plugs to make a laminated repair.
I got a few pics today but will post them together once I can get the whole repair roughed out. That way you can understand the sequence and the plan I have to make the headstock structure integral .
had to order a plug cutter and will get this back shortly
got back at this
as you can see another nightmare of armature repair.
after getting all the tuner and whatever out of the slot head I could then see what damage was done.
Aside from the cracks and over sized holes , they also over slotted the head stock. So I started by making plugs and ordering a new set of tuners.
The I used a stain to match as well as I could. In the end I had to use 2 bushings for the 11th and 12th string so the tuner post has something to ride in. That explained why the had scews and metal pieces here and there.
Here is more photos. when I tried the new tuners I found the issue of the slots being widened and I them replaced the plugs and went with 1/2 in for better structural stability. I had to use an end mill to avoid tearing up the thin walls and then glued in the plugs
