Duco failed
Duco failed
I built a guitar in 2014 and used Duco Cement to glue on the binding/purfling. I knew there was a good reason to take some pictures during construction
https://www.flickr.com/photos/ruby1638/ ... 029319394/
Most of an entire side of just the white binding came off - the purfling still looks very solid. I have never had this happen and have never had to glue it back on a finished guitar. Looks like it might have been incomplete glue coverage on my part, but hard to believe I would miss it for such a long stretch.
Does anyone have a suggestion for glueing this white plastic binding on without damaging the finish and causing the need for bunches of cleanup?
flickr dot com/photos/ruby1638/51324846073/in/dateposted-public/
Again, the curse of the single URL site - please piece it together. And check how the Osage Orange has changed color
Re: Duco failed
Post by phavriluk »
I'm afraid I don't have an answer, but a question. Is Duco Cement a solvent for the binding? We all know it glues up wood just fine, but for non-wood, testing might be wise.
And if the gallery here knew what the binding is, maybe someone can speak from experience about glues.
Re: Duco failed
John Hall uses Duco exclusively and claims to never have had a failure - that's why I used it. It sure feels and smell like a solvent, and after you used it you have to let everything sit for a couple of days before scraping as the binding is slightly bigger, then shrinks back down.
Re: Duco failed
never had a failure with duco
my method is to flood it on and wipe with a cloth to get it to migrate to all surfaces.
then tape for 12 hr.
I use acetate binding. I never used stew mac bindings I always got mine from Martin. I did find a celuloid binding from China that works well also ,
I see from your pics you used wood purfling , and do you know what kind of plastic your binding is?
Re: Duco failed
No John, I don't know what type of plastic it is - I probably got it from SM. And yes, the purfling is wood. I need a method to glue it back without having a lot of cleanup. I'm thinking CA. The piece had good shape retention and will go on easily, just need something that will stay a little neat.
Re: Duco failed
Re: Duco failed
I use 20 ca from Stew Mac for that type of repair the medium is easier to make less a mess and holds very well
Re: Duco failed
I have their #10 and some pipettes and my grandson who owns it has to go home on Friday, so I will give that a try. Thanks
Re: Duco failed
I've use StewMac's Bind-ALL Guitar Binding Glue and like it, although the price is insane; However, one tube should be enough tor 3 or 4 guitars, so the cost per guitar is not too bad.
