Trimming head plate on a slot head?
Monkmusic
Post by Monkmusic »
From another thread
Hey Monk, I thought everyone knew not to ask questions at Home Depot. :-))
Nice set of photos and nice job on the guitar. How did the headstock get
damaged? Did you receive it that way?
-tommy
No that was my poor workmanship on this headstock.
Any recommendations on the right way to trim the faceplate without this tear-out happening? It ended up ok in the end on #1 but I'd obviously like to do it right from here on out. thanks
https://www.dropbox.com/sc/9r6ossb1hms5lzj/CTZqKyS7M0
Re: Trimming head plate on a slot head?
If the slot in the neck is already cut, I use a flush cut router bit, very carefully set so that the bearing does not fall in the tuner holes. I do drill out quite a bit of the waste before routing. If I am making a neck from scratch I glue on the veneer before I make the slots.
on the lower part you may need to ramp the slot for the strings. Here I like a 1/2 rat tail rasp
