I have a curiosity question. I have watched the Martin Factory Tour U-tube clips a few times, and been personally on the tour. In one of the clips, there are a couple of technicians routing binding channels. They are holding the body cradled in their arms, and it appears that they are using a horizontal router to cut the channels. The do a body in perhaps less than 2 minutes, in a few sweeping motions. Are they using a special jig that i cannot see? Is this simply a matter of practice and 100 ruined bodies before they got it right? What exactly are they doing in the clip, and how are they doing it?
bert
Routing the binding channels
btberlin
Re: Routing the binding channels
I am lucky in that I have seen that personally. This is not like anything out there. The cutter is a lot larger and has the profile of the binding and purfling. The operator does this 8 hrs a day 5 days a week and is very skilled at this job. There is a good bit of hand work involved. He also has to sight the body in relation to the cutter.
The cutter is more like a shaper than a router and the cutter is about 3 in in diameter. The rest for the body the operator rides the guitar on is flat and if you watch him he does a cut on the back and stops at the upper bouts. He then makes adjustment and cuts the upper bouts on a 2nd cut.
Once cut it is passed to another operator that does a little hand work to blend the 2 cuts.
I am lucky to be a repair center for them and I have done some consultant work with them. The process is one that takes skill from the operator.
btberlin
Thanks for the info. I am planning a trip there again with one of my sons, and I will be sure to pay closer attention to that particular station.
bert
bert
