Tuner placement
Re: Tuner placement
this may help
Re: Tuner placement
Brian: John has given you good data. The placement is critical in that if you are not careful strings can hit each other on their way from the nut to tuners. For example the A string can hit the low E string and post if your lay out is not correct. Take notice that the tuner posts are not in a straight line.This lets things line up correctly. One of the little details that make life with guitar a bit easier.
Tom
Tom
Re: Tuner placement
What about aligning the posts so the strings come off the nut in a straight line? Any benefit or detriment to doing it this way?
Re: Tuner placement
This pattern - my drawing skills suck - would it not avoid unnecessary tensions, using a direct path to the slot in the nut, and also eliminate strings interfering with posts? Just askin' - I know nuttin' about nuttin.'.
DaveB
DaveB
Re: Tuner placement
As indicated in John's Drawing its important to note that the center posts are slightly inboard to the center line of the 1st and three. I also angle my nut slots toward the tuning peg to reduce the friction in the slot and the potential of string binding.
Re: Tuner placement
Is it that important to keep the traditional look, or is there a structural element that I do not understand?
DaveB
DaveB
